Red top/ starting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2007, 01:27 PM
I have a red top that have had less than a year. A while back the car sat a few weeks and would not start, jumped it drove around. Started for a few weeks. It rained for about 4 weeks went out started it drove to a show to look tried to go home and it would not start. I got a jump drove it home and have a charger on it. At the show it would not even click the starter. I have the battery in the trunk all new cable 1or2 ga. 80 alt, electric fan radio (never use). This started about the time I installed a radio and the car sat. Do you think it is the radio, starter to hot, bad red top?
Old 07-19-2007, 02:04 PM
302 Z28's Avatar
If you suspect the radio installation pull the fuse. FWIW there has been recent posts about the failure rate of the highly touted Optima battery.
Vince
Old 07-19-2007, 04:05 PM
Gummi Bear's Avatar
Sometimes the red tops do take a poo, more likely however, is that something you've added recently has a parasitic draw.
A simple test, if you're not an electrical savvy kind of person (or find it frustrating) is to disconnect the battery cable when you park it, if it starts right back up the next time, you've ruled out the battery as the culprit.
Old 07-19-2007, 04:59 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
RED TOPS are having an extremely Bad run on Battery's right now..
Charge the battery for 6 to 12 Hours, then take it and have it load tested..If it has bad cells it will fall off rapidly.
IF you need a new one, and you can apply warranty, get a regular battery..If not, you have a choice, go with one that may Die in 6 months, for warranty, or get a reliable one now and be done with it..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-20-2007, 09:16 AM
Gummi Bear's Avatar
The hot battery in the electric vehicle racing crowd is the Deka Intimidator. Once my next red top kicks the bucket, I'll go with one.
It's still a fully sealed AGM battery, and from what I'm understanding, they're holding up quite well.
http://www.eastpenn-deka.com/default.aspx?pageid=163
Top Fuel starting line procedure? Grogetter Hotrodders' Lounge 35 09-14-2006 01:10 PM
Starting Problem with 05 corolla xrs mmartin1872 Engine 7 11-10-2005 09:01 AM
Oldsmobile F-85 starting problem oldsF85 Engine 1 03-29-2004 08:21 PM
Remote solenoid: problem starting the engine darom Engine 9 03-21-2004 01:04 PM
GMC 350 Top End Oil Problem bns2002 Engine 16 12-11-2003 04:29 PM
