Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > General Discussion > Site Suggestions and Help
  #1
Old 05-13-2008, 08:16 AM
65smallblock 65smallblock is offline
Rediculous article
I find the "why NOT TO use a CSB engine" article to be biased at best and bordering on downright stupid.
Citiing, very common, highly available, reliable and cheap to build as reasons NOT to use a CSB is clearly coming from someone with an axe to grind.
How about throwing in a "reasons for chosing a CSB" article in to keep things in perspective?? Cant think of any "reasons"?? How about highly available, cheap to build, reliable ... ... need more? no problem, wide spectrum to suit different purposes, more aftermarket parts than any other engine on the planet, huge HP potential, easy interchangeability... Things that make me go HMMMMM???
Old 05-13-2008, 08:33 AM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Moderator
 Henry Highrise's barnstar
Wiki Edits: 4
re: Rediculous article
Where is this article that you speak of? Is it in the WIKI ? Or are you talking about a thread here on the Bulletin Board? Please provide a link or a url so we can all see what your referring to. Thanks
Hotrodding is much more than just owning a hotrod...It is a state of mind!
Old 05-13-2008, 10:06 AM
matt167 matt167 is offline
 matt167's barnstar
Wiki Edits: 19
It's in the Wiki.. it's 1 of the last in the list that appears on the bullitin board top in the " How to build " section.. I just noticed it there at quick glance
Old 05-13-2008, 10:09 AM
 matt167's barnstar
Wiki Edits: 19
but also, there is an article on why to use a Chevy small block, I can't remember the title but it's in there, just have to look for it... so everything is in perspective.
I don't think you understand the full extent of the article. it's aimed at street rods and hotrods, not high hp vehicles where every hp counts.. but cars that should be diffrent than the next, even if there the same make/year/model.. Hot rods w/ SBC's are common and the value of a SBC powered hotrod can be lesser than say a Buick Nailhead, or an Early Hemi..
Old 05-13-2008, 12:06 PM
Jon's Avatar
Jon Jon is offline
Administrator
 Jon's barnstar
Wiki Edits: 3,456
If there's not already a "Why to use a SBC engine", feel free to start one. The wiki is very democratic -- anyone can start or edit any article.
Old 05-13-2008, 12:46 PM
F&J F&J is online now
Ok,I'll admit I did not read the Wiki yet, BUT...the "first two" reasons you posted for NOT choosing a sbc, seem to hold true if a person is building an open hood/hoodless rod. I've seen so many cars built in a trad style, yet the use a modern sbc. Good grief, at least put as much effort in the motor, as the rest of the build ... What the heck is so hard about finding an early sbc, with maybe 265 manifolds, maybe double bump heads, oil fill pipe, etc??? Instead, there is a brand new sbc crate motor...and the usual excuse is "i want something reliable"
Old 05-14-2008, 08:15 AM
Had to edit after re-reading your post. I can appreciate uniqueness. So you made a reccomendation of something other than a crate motor. Thats fine, but the article doesnt, it simply baggs on the CSB. If the article read "Other options for builder motors" and then made some suggestions it would have made a lot more sense. But to simply put down perhaps the greatest classic motor of all time because of their success.... Sorry, that dont flush..
Old 05-14-2008, 10:13 AM
OK, I did my own article. The controversial Chevy small block. But apparently I did something wrong, the format seems screwed up. ?? Can someone help with that?
Old 05-14-2008, 10:23 AM
Jon's Avatar
Jon Jon is offline
Administrator
 Jon's barnstar
Wiki Edits: 3,456
Nice -- the article is off to a good start . I've just fixed the format.
Old 05-14-2008, 10:38 AM
HR site seemed to have a problem early this AM, could not even get the url to show in the browser after using my bookmark.
Now it's Sooo slow to get to the coalition page and then worse delays getting to it's idex. Got to the index, and can't find his new wiki? or did he add to the old one ??
To 65sb; I did read most of the old wiki, and I really don't see what is so offending? except maybe the comment about the sbc is less powerful. That's wrong as we know, BUT there is a note there saying this comment needs facts & figures added ("as a wiki edit" I would guess?)
Old 05-14-2008, 11:29 PM
You dont know whats so offending? How about the title of the article?? It is an article with one purpose, to attack the CSB.
Jon, thanks..
Old 05-16-2008, 12:20 PM
MARTINSR MARTINSR is offline
It's only "offending" if someone should take it personal like saying they dress funny or the kids ugly or something. We are talking about a motor here, not a boob job.
Old 05-16-2008, 01:40 PM
Moderator
Wiki Edits: 4
Jon, thanks..
Good gosh man...everybody wants us to be "politically correct" and now...you want us to be hot rod correct. Sheeeeesh. Build them like you want them with whatever motor you like. Its all good.
Old 05-16-2008, 01:44 PM
poncho62's Avatar
poncho62 poncho62 is offline
Moderator
 poncho62's barnstar
Wiki Edits: 4
Besides, you should not be saying "CSB".................it's "SBC"..........That's like saying "IMEH" instead of "HEMI"..............and, you wouldn't want to upset those RAPOM guys...................
Old 05-16-2008, 02:54 PM
Jon's Avatar
Jon Jon is offline
Administrator
 Jon's barnstar
Wiki Edits: 3,456
The pro-SBC article complements the anti-SBC article. On each article, we can add a link to the opposing argument. Or, we can combine them into one article.
The point of the wiki (in this case) isn't rightness or wrongness. It's efficiency. We spend countless hours debating the SBC controversy. It makes more sense just to document the various viewpoints on one page, rather than having everyone repeat their argument every other week when this issue comes up. The time and social energy that we save in the process can be invested in more constructive pursuits.
Anyway, job well done 65smallblock . Rather than just complaining, you put your money where your mouth is, and started a wiki article to document the opposing viewpoint.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Rediculous article"
Thanks Sprecher48 for VW engine basics wiki article Jon Engine 1 05-05-2008 01:08 PM
wiki article: Cheapo Paint Job Jon Body - Exterior 0 11-13-2007 11:08 AM
need help on wiki article: pitted rust Jon Body - Exterior 4 08-07-2007 08:38 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
