Redneck Performance - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2009, 06:36 PM
Redneck Performance Experience
Recap of Transmission purchased on eBay from RP $1,500 with shipping
FORD C4 TRANSMISSION (LOADED)- C-4 REV MAN TRANSBRAKE
I bought this transmission because I had bought a torque converter previously and had good results.
RP did not usually answer the phone when I called.
RP phone call backs were hours or a day later. Usually late afternoon.
RP closes their entire office for a week.
RP's website is has missing pictures on their web site.
The Registrant Contact for the website URL is Alan Hartmann whose email is ahartman@artcarr.com
1. The transmission that I purchased was leaking excessively after I drove it. Thereafter, it would leak once it got warmed up and I determined it was leaking from inside the bell housing.
2. As suggested by RP, I pulled the transmission and they sent me a new pump and gasket that I replaced.
3. After installing the transmission again it did not leak But, it does NOT go forward or backwards when shifted. It does go in and out of park.
4. As suggested by RP, I put washers on 1/4 inch washers on the torque convertor which was very difficult since the torque is threaded and does not have studs.
5. This washers did not make the transmission work.
6. I asked for a refund but I would have to pay shipping back and only had a 10 days to return.
Old 09-02-2009, 07:11 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Sorry to hear your frustration. I bought a torque convertor and a transbrake kit from them and have had no problems but never bought a complete transmission. I had emailed them a couple of times during the install of the transbrake and had an answer the next day. I was considering exchanging my torque convertor for a smaller stall and they said they would exchange it if I paid shipping but I never did, just kept what I had. I done all this work last fall. Hmmmm.
Old 09-03-2009, 02:18 AM
DoubleVision's Avatar
Had it been me and I got a leaking tranny it would have went back then for them to fix. I don`t believe in the "I`ll send you the parts you can fix my screwup" deals but that`s just me. They sent you the parts for you to fix and now the tranny doesn`t work at all spells out they didn`t want the tranny back.
Old 09-03-2009, 02:52 AM
Thumpin455's Avatar
Ask me about Ethanol
Last journal entry: 65 GTO
When you replaced the pump did you hear anything fall inside the trans? Pull the pan and see if the struts for the bands are still in place. Also if you didnt use trans gel on the pump when you stuffed it back in you might have broken some of the seals. Park is a pawl that contacts teeth on the output shaft (more involved yes, but basically thats it) you release the pawl and the car will move, put it back in park and the pawl engages and keeps the car from moving easily. Since nothing works its pretty safe to assume you have an internal fluid leak or a broken front pump.
Would you want to fix it, send it back, or ??? If you want to fix it a C4 is one of the easiest transmissions to work with. I can get you the info you need to fix it if you want, also you can do some trouble shooting with the pages in herehttp://s189.photobucket.com/albums/z278/AuCinaoaMie/Cars%20and%20trucks/Transmissions/C4/
Old 09-03-2009, 09:06 AM
ericnova72's Avatar
More for Less Racer
When you installed the new pump, you did have the trans stood up vertical with its tail facing the floor, right?? You can't do it with the trans laying down, stuff falls out of alignment when you do.
Have seen several racers in my area with Redneck Trans and converters with no reported problems.
