Red I used that primer for years as has Jim... I had to go to 2.0 tip to get it to atomize correctly... reduce it 5% and if that does not do it, go to 10% as crash has suggested... it will be fine, just build a tad less... a note for the use of that primer...make sure you sand down anywhere you are going to use it... it will fill most anything for now, but over time in the sun it will break down and if you have coarse sanding scratches like 80 grit, they will bleed through... trust me, I have had this happen with that exact primer years ago... I know they are not making it better than they did back then... used some of it last year before finding spi, and I liked it less than years prior
