Reducing Chroma Clear HC-7776S - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2009, 04:09 PM
A friend of mine has been using Chroma System Base Maker reducer with ChromaClear HC-7776S to reduce it. He's shooting small fiberglass cowling parts maybe bucket size pieces. He has been doing this as a 2nd final coat shot over a cleared in 1st coat cleaned up with 600grit. His process looks good finished out. Anyone heard of this and is there merit to it. Sounds kinda corny to me but it looks like it works pretty well..Thoughts?? Thanks Walt
Old 06-05-2009, 04:59 PM
brainsboy's Avatar
brains
The process of clearing and letting it dry, then going back over with 600 or 800 and clearing again is fairly common with some painters.
As for reducing its hard to say. Everyone has their own method for painting and what many people dont realize is no two spray guns are going to spray paint the same. Many methods are from painters who use the same gun every time and perfected their own painting skills with the equipment they have. If he is using a 1.2tip and you try the same thing with 1.5 then you will get completely different results.
Just how much does clear "fill", a little test I did. MARTINSR Body - Exterior 26 10-28-2009 09:31 AM
chroma base clear 72500 kkinney Body - Exterior 4 03-13-2007 04:50 PM
Problems with clear; fisheyes, never dries joewhite Body - Exterior 4 10-01-2006 07:05 AM
Clear, No Clear, or Clear + Base? tallpaul Body - Exterior 16 01-21-2006 06:30 PM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 03:52 PM
