reducing pictures - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2005, 08:10 PM
RONNYinWAXHAW's Avatar
Last journal entry: And then this happened...
reducing pictures
I'm not that good on a computer. I've been trying to reduce a picture of my El Camino to use here, and I aint having much luck. Once I got the size right, it still had too many bytes. All the photos I have would qualify as "before" pictures. The word "patina" comes to mind. I've stumbled through the photo editor program, but I can't get it to fit. Any ideas?
Ronny
Old 09-15-2005, 08:24 PM
skeeveman's Avatar
I am the Antirice
What operating system are you using? Windows I'm assumming, but which one? XP? 2k? 98?
Old 09-15-2005, 10:12 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
email them to me (there should be a little pic, usually a paperclip or something) that allows you to attatch pictures to emails. I'll downsize them and send them back. My email address should be at the bottom of my post here, (little oval with 'email' in it). If not, click on my username and under contact info click send an email to ChevelleSS_LS6
also, welcome to the forums, if you need help aorund the site, they have a place for that here http://www.hotrodders.com/forum/site-suggestions-help/ (click on yellow text).
-matt
Old 09-16-2005, 12:42 AM
I think www.photobucket.com (a hosting site) automatically sizes pictures for message board use.
Old 09-16-2005, 02:14 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Save the pic as a jpg. instead of a bitmap (bmp) To do this open the picture in Microsoft Paint, then "file", "Save As", and change the extension at the bottom to "jpg". This will reduce the bytes considerabely.
Kevin
Old 09-25-2005, 01:43 PM
pictures
My computer runs XP. I went to photobucket, registered, loaded the picture, and it's still too big to move here. It was already in the jpg. format before I took it to photobucket.
Old 09-25-2005, 03:05 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yep the forum Site Suggestions and Help is where this needs to be ...There is a thread there now on this same subject and here is what Jon had to say about it . Quote from Jon: There are several different systems in place for the board, photo album, etc. that watch for extra-large pics before posting them on the site.
Can you show me the pic? Either send it by email to jon@hotrodders.com, or try to post a link to it if it's on the web.
Also, are you trying to upload it to a board discussion? Photo album? Let me know.
Either way, the picture will have to be shrunk down to size. This is a fairly basic task if you're familiar with a graphic editing program. If not, if you can point me to the pic, I can take care of it.
Old 09-25-2005, 05:30 PM
pigjamelectric's Avatar
oldsmobile compatible
Last wiki edit: Selling your car Last photo:
Wiki Edits: 29
I reduce them using microsoft paint, the basic little program that comes with windows.
Open Paint
Load the picture you want to use
Click on the "Image" menu
Click on "Stretch/Skew"
In the stretch section, put a number between 50 and 75 % for both horizontal and vertical
Click OK
Save as a different file name so as not to affect your original, and also on the "Save as" window, make sure the "Save as type:" (on the very bottom) is JPEG instead of "24-bit Bitmap".
Hope this helps
Paul.
Old 09-26-2005, 05:51 AM
mrcleanr6's Avatar
other than changing it to a jpg. you need to make sure the resolution is set at 72dpi. anything over that is useless since a monitor only displays that.
Old 09-26-2005, 06:47 AM
rrmccabe's Avatar
GM Muscle
Microsoft has a free download which is part of their powertoys suite.
Its called image resizer. You can download it hear. http://www.microsoft.com/windowsxp/d...powertoys.mspx
When installed you just RIGHT CLICK on your picture and select resize pictures. It gives you the option of a few common sizes. It creates a copy of that image in the same directory as the original. You can do one or hundreds at once. Big time saver.
Rich
Old 09-26-2005, 10:32 AM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
I've seen a lot of JPEG images lately that are huge in filesize for the image size. Apparently MS's resizer is too dumb to realize that JPEGs are compressible. Several times I've downloaded these images and found that no compression was used. The file size was 2 to 3 times larger than needed for the image. This is significant when you have a page with several 300K images that could just as easily be 100K to 150K each.
The lossy JPEG format was developed by pros for the specific needs of photos rather than technical drawings. For the latter, you need a lossless format such as PNG. It is extremely rare that you need to do lossless compression on a photo that is being reduced for display on a monitor.
I suggest you install Image Magick ( self installing binary -- http://www.imagemagick.org/download/...indows-dll.exe ) and use it. See http://studio.imagemagick.org/script...line-tools.php
If resizing an image by typing 'mogrify -geometry 800x800 copyphoto.jpg' is too stark for you, try gimp ( http://www.gimp.org ).
Old 01-15-2006, 09:40 AM
Here's what I use:
http://www.dvdsmiles.com/?Content=ConvertImage
heres the pictures of my car you asked for 454me Engine 7 01-07-2005 09:04 PM
Posting pictures lluciano77 Hotrodders' Lounge 3 08-21-2004 08:15 PM
Help with posting pictures,....PLEASE? OddRodder General Rodding Tech 18 02-18-2004 10:17 PM
Can't Down load pictures tm454 Hotrodders Site Suggestions and Help 2 10-28-2003 06:45 PM
Local car and engine pictures for you guys nicefrog Engine 10 01-06-2003 03:25 PM
