Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - reducing road noise
Old 07-17-2011, 09:07 AM
boatbob2 boatbob2 is offline
boatbob2
lizard skin.........
To start,LS is overpriced,i made my own,1 gal of white paint (water soluble) and 2 lbs of micro spheres (Aircraft spruce co,) mixed with a drill,used an undercoat gun to apply,sprayed 2 coats (allowing 1st coat to dry)then sprayed 2nd coat,then bought bubble wrap (home depot) sprayed wrap and my homemade LS,with 3m contact cement,stuck wrap to my LS,put door in sun,(outside facing sun) got a 75 Degree reduction on temp ,measuring inside to outside with temp probe.
