Reducing water from compressed air for painting - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2011, 01:03 PM
K72Nova's Avatar
I know this has been gone through before but I couldn't find exactly what I'm looking for. I am getting ready to run my lines for my shop air and I'm trying to figure out what filters I should use to reduce the largest amount of moisture without going for an air dryer or refrigeration unit. I plan on plumbing the system to have plenty of ball valves to release pooled water; I am really just trying to figure out what types of filters to use. I have heard of using different filters in series but I'm really not too sure which to put where. I will be doing a bit of media blasting and maybe some painting but most likely nothing major. I have a good pipe system mapped out to reduce the max amount of moisture before it ever reaches a filter. I can upload an image of the pipes at a later time I just don't have that file on this computer. So what are you using? Does it work well? Any info would be appreciated.
Old 12-19-2011, 01:41 PM
This is what I do. I use this extra tank.
I run regulated air at about 40 PSI, through the red hose, and the filter into the tank. Any water after the filter goes to the bottom of the tank and stays there. I take clean air out of the fitting with the blue hose.
Using the compressor mounted regulator allows the air to expand and cool before entering the compressor end of the red hose. This lets some of the water vapor to condense out in the red hose, so the water trap can catch it. No water trap will stop water vapor in hot air, and when the air cools water will condense out of the compressed air.
This is my old Sears 3 HP compressor.
By using the dump tank, it is possible to paint with this LPHV gun. The compressor cycles on and off when painting, and so far, the compressor actually spends more time off than on. But I have only painted smaller parts, and single panels so far.
Old 12-20-2011, 05:15 AM
K72Nova's Avatar
That's a really good idea, thanks!
Reducing 24v DC to 12v DC DaSouthWon Electrical 21 02-07-2011 09:03 AM
water in compressed air, what do i need? 406 ss monte Garage - Tools 3 02-07-2010 09:51 PM
reducing 2K oldred Body - Exterior 11 05-08-2006 05:07 AM
Capturing water for painting rick458 Body - Exterior 19 03-07-2005 06:14 PM
painting in garage... water heater concerns? Eddie N Garage - Tools 18 03-09-2003 08:06 AM
