Refilling a Super T-10 with Gear Oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2003, 04:04 PM
redcamaro4spd's Avatar
drive it like you hate it
Post Refilling a Super T-10 with Gear Oil
Anybody know how I do this? Is there a pump or is there an opening in the top? I only see the drain plug...
Thanks for the help...
Old 05-14-2003, 04:37 PM
Post
Sorry, should have looked before I posted. I see two drain plugs, one at the bottom and one halfway up the passenger side of the tranny. I read that you just unscrew the middle plug and fill to the bottom of that hole, is this correct? Also, is 80W-90 a good wieght oil?
Thanks again
Old 05-15-2003, 07:03 PM
Post
80w-90 is a good choice. the super t-10 only holds a little over 1 quart when it's completly empty. If I remember correct it's 36 ounces.
Old 05-16-2003, 04:12 PM
Post
well I added some today and it still is making a little too much noise for my comfort, but it is better than before, thanks for the reply
