refinishing aluminum wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2009, 07:31 PM
hey guys i am working on a set of iroc wheels,what do you spray on them to keep from oxidation? And where do you get the gold inlay color and what can you strip the old finish with? Is there a special kind of paint and clear for aluminum?
Any information will be greatly appreciated...
Old 06-10-2009, 07:28 PM
Fringo's Avatar
To paint aluminum, you have to use a special primer, onc you've primed it properly you can use any paint on it but because you are going to clearcoat the wheels you can't really do that. I've used an exterior lacquer on aluminum wheels before with decent results. I think that its more important that you prep the area well and clean it up using different grades of wet & dry paper until you get the finish that you want. To do the gold, just get the same brand of paint as the clear. You could also try your local auto parts store, they may have a product just for that, and keep in mind that depending on the climate where you live and the driving conditions the finish is only going to have a limited lifespan anyway. My '02 Silverado wheels started to go after the fourth year, but that is S. Ontario with all the snow and road salt.
Fringo.
Old 06-11-2009, 07:26 AM
What kind of primer? Is it the kind with zinc
Cast Aluminum Wheels Dominick Harman Hotrodding Basics 3 10-22-2008 12:07 PM
Removing clearcoat from aluminum wheels Nitrousbutton Body - Exterior 5 10-01-2006 05:03 AM
Wheels Wheels Wheels chevymastermind Hotrodding Basics 2 02-22-2006 06:18 AM
Balancing polished aluminum wheels jpd37 Suspension - Brakes - Steering 3 07-17-2003 12:01 AM
polishing aluminum wheels 65galaxie500 General Rodding Tech 7 02-10-2003 07:34 AM
