Refinishing the Bottom Side - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2009, 04:13 AM
I'm getting ready to remove all coatings, rust etc from the underneath of my 64 Falcon. The floor pans are approx 27" off the ground and I am trying to decide how to finish the bare sheet metal. Because of the height my first thought is to use some type of roll on bed liner. I do have one of those old style suction guns w/ the 3 ft hoses attaching the gun to the paint can and I can adequately cover the floor if necessary. I am willing to sacrifice ease of application for a good durable finish if necessary. I'd appreciate being able to lean on you guy's experience..help
Old 11-25-2009, 04:14 PM
millercustomfab's Avatar
You could always go the POR15 route, followed by their chassis black. Or start with a epoxy primer, and paint. Depends on what you want it to look like. If you blast the bottom a roll on bedliner will work, but go with a more expensive brand. I've used dulpi-color on a bed, and even with proper prep it didnt want to stick after a few months.
Old 12-06-2009, 02:00 PM
Rix-Trix's Avatar
Last journal entry: Box is back on the truck
some ideas for you
No matter what bare metal must be sealed. Since you have a gun there are lots of good 2 part epoxy sealers out there, leave an hour dry time then you can roll on the box liner, or you can buy sealer in a spray can all though the quality is not as good but will work if you don't want to mix epoxy or use your gun.
Floor Pan Refinishing (LONG) Psquare75 Body - Exterior 1 05-29-2007 09:47 AM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
Oil coming up one side only..help! TVR383 Engine 5 05-02-2004 09:35 PM
one side is1.75" lower than the other side. brian400ex Suspension - Brakes - Steering 15 04-01-2004 04:34 PM
