Refinishing my fiberglass tail - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2009, 12:59 PM
Whiskyb's Avatar
What started out as a simple scuff and shoot last fall has turned into a full strip to metal project for me. I am working on some fiberglass right now that I was hoping to just sand off the clear coat. Unfortunately I sanded through in one area and luckily I found out a far worse problem. Having a hard time getting a good edge and noticed that the topcoats were somewhat lifting. Grabbed a scraper knife and was ablt to take off chunks of paint several square inches in size. Underneath seemed like it never was prepped as it was still shiny glass. Some areas did stick so their is some sanding. I do have some cracks to fix and was going to be using West epoxy. My question is will it adhere if I use a Nason primer/surfacer first on the whole piece or should I do the epoxy work first.
Thanks for any advice
Old 06-28-2009, 06:02 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Do the epoxy work first before any paint..
Sam
Old 06-28-2009, 06:16 PM
Whiskyb's Avatar
Thanks Sam, I kinda figured that's what would have to be done but at this point needed to be sure. I'll do the epoxy work, hit it with the primer and then any small stuff I imagine I can do with a 2part putty.
Thanks again
Yet another question about bonding fiberglass to metal Psionic Body - Exterior 41 10-20-2013 07:56 PM
Sanding the *%^$&# primer all off the fiberglass parts Ripped Body - Exterior 7 09-01-2007 08:56 PM
Mounting fiberglass dash mrmagoo187 Interior 24 11-04-2005 06:43 PM
fiberglass to fiberglass scoop bluebu Body - Exterior 62 06-23-2005 06:15 PM
Fiberglass help for novice tyman00 Body - Exterior 1 10-20-2004 01:36 AM
