If this is a show truck - ignore this product for the top surface. As far as the trailer goes, if you just want to protect the wood from the elements try Thompson's Water Seal or a similar product intended for decks. I redo my trailer every two or three years, same as the deck on our house. It can be applied with a roller on the flats, but use a brush to be sure to get the ends good, and allow for drainage between the boards on the trailer. It will also protect the wood from light dirt, but if you are hauling engines around, not so good.
