stick welding sheet metal ... wow I know it can be done cause stick has been around longer then mig, but good luck. I here welding is like riding a bike, and I am sure your touch will reappear after a few good sticks get stuck, welded to you work.. you are right about the 20 gage, if not right on I'd say very close . memory falls me at the moment
It's going to take far more than just a refresher to weld weld 20 ga. with stick, It will take major skill. You might want to look into getting a MIG if you need to weld something that thin.
I have been welding for many years and I don't stick weld any thing thiner than 1/8" and up. For body sheet metal I use my MIG with a wire called 20gauge. It is sold by J.W.Harris. It is the best I have found for MIG wire on thin materials. It is an iron cored steel wire and you need to use C25 gas with it as recommended by the manufacturer. I also use TIG on the really thin stuff or oxy/accet depending on what I am welding at the time. MIG is fairly easy to learn also, I would recommend a MIG welder with the gas setup for what you are wanting to do, just my 2cents worth.
Gc, I too have been a welder for many years and although it is certainly possible to weld thiner than 1/8" with stick it becomes very difficult even for those with experience and as for welding 20 ga. with stick, it can be done BUT
.... That J.W Harris wire you mention is the absolute best I have ever used on thin sheet and for someone using a 110 volt MIG it simply allows the 110 outfit to do things it could not do nearly as well with solid wire.www.jwharris.com/images/twentygauge.pdf |
My first experience using a MIG on sheet metal was welding the top I chopped on my car. A real experience for me. I began to panic when I started blowing holes in the metal. So I cranked the amps down, but then I couldn't get a good weld. It just takes a lot of practice to get the correct setting for your machine. I was using a .024 wire but I'm going to try the .020 wire you folks have mentioned for future welds on the thin stuff.
Red, That wire is actually .030 but it is a cored wire (not to be confused with gassless) that means it is a tubular wire with an iron powder core that will weld with a lot less current than the same diameter solid wire. It is amazingly smooth with little to no spatter and will make a really good weld at a ridiculously low power setting which translates to less panel warpage and burn through. I have found this to be a very versatile wire that can be used for a lot more than just body panels since it makes a strong clean weld.
Thanks Oldred. I looked up the link you provided. Now to purchase it and try it.
gcrmcc |
I forgot to mention to all of you that are using a 110 volt gasless flux core welder. J.W.harris also has a wire called 10gauge that is the iron core with flux for thin sheet metal, it won't quite weld as thin of sheet metal as the 20 gauge but I know a few people that are using it and with practice and they seem to be welding body sheet metal with the 10gauge pretty darn decent.
| Recent Garage - Tools posts with photos |
| Welding info | Kevin45 | Body - Exterior | 10 | 08-26-2011 08:09 AM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| welder reccomendations? | rally4x4racer | Garage - Tools | 32 | 10-14-2008 09:00 PM |
| Parasol Metal body filler. | x711 | Body - Exterior | 16 | 02-14-2006 09:47 AM |
| Got a welding coach | cboy | General Rodding Tech | 61 | 10-28-2005 09:03 AM |
