Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - regular bushings or polyurethane bushings?
Old 02-01-2003, 01:14 PM
edubois edubois is offline
New Member
My experience with polyurethane is that they last longer, are a little stiffer, and depending on which ones you are replacing, they come in cool colors. I've heard it is recommended that if you start replacing some parts with poly, you should probably try to do all of them, or be consistent if you're doing just a few.
