Relationship between Gas Pedal and Brake Pedal - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2011, 10:09 AM
35WINDOW's Avatar
Last journal entry: Engine!
I am looking for pictures of your Gas/Brake Pedal set-ups-I am working on placing my Steering Column, and decided to make the hole in my floor for my Brake Pedal, and mock-up my Gas Pedal to see how much room I have and where to put the Column. Anyway, after looking at the situation, I will only have about 2-2 1/2" between my Pedals (if I offset my Brake Pedal on it's pedestal)-seems kinda tight, so I am looking for inspiration-anybody got any?
Old 12-21-2011, 06:48 AM
327NUT's Avatar
These are just pics I found on another website and they are '32 Fords. As you can see they to are pretty tight but that's just the nature of the beast. With your '35 you may have a little more room, forgot if your's has a clutch peddle or not but you can move the gas peddle over a little (????) if it's an after market type. Hope this gives you a little indication on what you can do..........Dave
ID:	60956   Click image for larger version
ID:	60957   Click image for larger version
Old 12-21-2011, 07:40 AM
delawarebill's Avatar
peddal gap
i can tell u from experiance.... make sure the ped's are far nuff apart the if ur bk ped goes to the floor u don't push on the gas.... my first bucket m/c failed and close nuff i was hitting the gas, did a sideway turn and hit a sign.. couldn't figure what was going on.... fixed that on second bucket...
Old 12-21-2011, 07:53 AM
Wiki Edits: 27
tight fit.
I still have my old T bucket, I found the Body In ' 51' . I used a big foot print gas pedal, about in the center of the dash, brake is ok but I always have my left foot on the clutch pedal , No room to put the left foot any where else . I had a friend that had an old dirt circle track car and when I sat in it I liked the tall hand brake on the left side. he could have his foot on the gas and left hand on the brake to come out of corners faster. I used a tall original T hand brake in the same location and I like having it there , easy to grab.
Old 12-21-2011, 07:59 AM
Wiki Edits: 27
go fast cobra
The same problems in a Cobra, A good friend is the retired director of Ford racing, He still has his original Cobra, Much Modified and he still races it ..He Won the Optima in 2009. There is info and picts of what he did for pedals on the Club Cobra site, just search cobra # 3170 ,
Old 12-21-2011, 01:00 PM
35WINDOW's Avatar
Thank you for the pictures! Mine doesn't have a Clutch, and I am amazed at the one picture showing the Gas Pedal on top of the Trans hump-I had to make my Hump bigger to handle my 4L80E, but it is still the same distance from the hump to the pedlals, only taller than before-I am using a Clayton Machine Works Throttle Pedal, which isn't adjustable, and I don't have room to move it because of the tunnel-
I was thinking about it last night, and I may have to either live with it or modify the bracket (or pedal) on the Frame-
Here's the Pedal:
http://www.claytonmachine.com/throttle-assy.html
and the Bracket:
http://www.butchscoolstuff.com/store...s/98_large.jpg
Old 12-21-2011, 01:34 PM
327NUT's Avatar
That's the problem with the shiny billet stuff.......you can't bend or modify it without screwing it up. You may have to re-think the layout a little but I would def. move the throttle pedal or even install it on an angle before trying to move the brake assembly. The brake pedal arm could be bent to give you the needed clearance, just have to get in there and see whats best for your rig. The early Fords "usually" have a fairly flat floor or mild hump which makes it easier to do the layout for the accel pedal.......good luck.
Old 12-21-2011, 01:39 PM
35WINDOW's Avatar
Thanks Dave! and thanks to everyone who posted!
Old 12-22-2011, 01:03 PM
Last journal entry: My Last Hot Rod
the side break was needed for restarts you didnt have room or time to play with the brakes, clutch and gas all at the same time. The clutch was in and the gas was floored you used the side brake to stop from running over the other cars in line
for a 40 car restart
Old 12-22-2011, 01:16 PM
Last journal entry: rumble seat work
pedals
I have a 31 chevy coupe with brake and clutch not much more than 3" between pedal arms. hope you have small feet but it works.
Old 01-11-2012, 11:57 AM
35WINDOW's Avatar
Well,
I thought I'd post a small update-here is a picture of said Pedals (I've since added the Seat, and the bottom Steering Mount, my new Flaming River 1 3/4" polished Stainless Column should be here this week)-it's tight, but it will have to work (as I've cut the Floor! gasp )-
Old 01-11-2012, 01:31 PM
Irelands child's Avatar
Craig - sorry I didn't see this earlier.
This is mine for the '31. In my example, I needed to keep the accelerator pedal bell crank in line with the throttle arm as I'm using a solid linkage instead of a cable. The brake pedal is fairly close to the steering column and actually further from the accelerator pedal then my wife's now gone Ford Escape. I do wear sneakers/shoes with a narrow sole, just to add a bit of room, but had to on that Escape as well.
(That stuff hanging down was 'fixed' as this is a before registration photo )
Dave W
Old 01-11-2012, 01:35 PM
35WINDOW's Avatar
Thanks Dave,
It doesn't look like my Pedals are too much closer than yours, but my Tranny hump kinda gets in the way! Thanks for posting!
Low Brake Pedal MidnightFord Suspension - Brakes - Steering 2 09-05-2011 10:29 PM
brake pedal sxcorpio Suspension - Brakes - Steering 1 04-24-2007 08:41 PM
low brake pedal bct Suspension - Brakes - Steering 1 11-15-2005 06:07 PM
Low brake pedal jpd37 Suspension - Brakes - Steering 6 06-15-2004 11:18 AM
brake pedal astrops Suspension - Brakes - Steering 2 06-02-2004 07:32 PM
