Relay for brake pressure switch question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2006, 07:03 AM
I went with a Ron Francis inline brake pressure switch on my model A hot rod. I keep hearing how they fail with regularity. Would installing a relay help or does anyone or does anyone have any suggestions?
Old 06-11-2006, 07:31 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
That depends on what's causing the failures..
If it's high pressure then a relay will do you no good...
If it's internal contacts , then yes, It will reduce a 15 to 20 amp draw through the contacts down to an amp..(your switch will last forever..or until pressure blows it out..)
You Could just install one in hopes that the failures were contacts..as preventive medicene..(never hurts) and see where it goes from there mechanical~wise.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
oil pressure question jody chevelle Engine 16 08-02-2010 06:59 PM
Gas Guage and Kill Switch question Bo_Jangles Electrical 9 05-01-2003 09:54 PM
Fuel Pressure Question WheelMan Engine 1 04-21-2003 06:03 PM
Kill Switch Question PrimaDude Electrical 4 12-22-2002 12:52 PM
fuel pressure question for a 350 SBC HotRodF100 Engine 15 05-13-2002 02:29 PM
