Relay Help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 09:14 PM
Relay Help needed
I need some serious relay wiring help
Could someone help me wire this correctly..????
The fuel pump, radiator fan and vacuum pump need to be turned on when the key is in the 'on' position.
With key in the 'start' position the radiator fan and the vacuum pump turned off.
The horn and headlights are controlled with switches.
Can some kind electrical wizard help me with this drawing ,, please
Old 04-21-2011, 10:11 PM
302 Z28's Avatar
Here is a couple of sites to help you with relays.
One
Two
Three
Vince
Old 04-22-2011, 10:18 AM
More specifically, how do I wire a relay so the device will turn off when the key is moved to the start position from the on position..
So, turning off a device momentarily
Old 04-22-2011, 10:43 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
An additional relay will be needed to operate (energize) whenever the Ignition switch is in the start position.
This relay coil (85,86) will be wired to ground and start.
The normally closed contacts (30,87a) will be wired to open the common circuit or common ground feeding the coils of the relays controlling the pump and fan.
When the ignition switch is returned to ON the relay will deenergize thus restoring the pump and fan.
vicrod
Old 04-22-2011, 11:37 AM
Joe G's Avatar
Another way to make the relay on when the ignition is on, but cut out while cranking, is to wire the 85 terminal on the relay to ignition-on power, and wire the 86 terminal to ground through the starter solenoid via the crank wire
Then wire the load side of the relay as stated in the links above.
Hope this helps.....
Old 04-22-2011, 05:08 PM
EOD Guy's Avatar
This will do what you want it's in pwr point
Old 04-22-2011, 08:25 PM
Hoptup32's Avatar
Here is a simplified diagram showing the relay setup
Old 04-22-2011, 09:15 PM
Throwing a HUGE thank YOU ...
it works...
THis site is the BEST !!!!
THANK YOU ... THANK YOU THANK YOU
Old 04-23-2011, 06:16 AM
EOD Guy's Avatar
Nice job 32
Old 04-23-2011, 07:26 AM
Hoptup32's Avatar
Thanks EOD and dar130
I love it when a plan comes together.....
Old 04-23-2011, 10:53 AM
EOD Guy's Avatar
What did you use to create the dia? I use pwr point it, works but sometimes is time consuming...hence my simplified dia.
Old 04-23-2011, 12:21 PM
Hoptup32's Avatar
That diagram was created in AutoCad, printed, and I scanned the print into a pdf file for uploading. I use AutoCad at work everyday, so its convenient and quicker for me to generate drawings. I haven't tried powerpoint, but I've tried Mircosoft Paint and a few other programs with limited results. There may be some freeware CAD programs that may be found to produce similar results.
MSD Relay V305 Electrical 1 12-04-2008 06:11 PM
4 pin relay ? butch27 Electrical 9 11-09-2006 05:34 PM
Relay Help Needed MI2600 Electrical 2 08-20-2006 09:07 PM
Elec. fuel pump relay needed? upstand2 Electrical 4 05-10-2005 05:21 AM
using a relay w/ msd Slant3 Electrical 0 06-11-2004 08:10 PM
