Relay Help Needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2006, 11:40 AM
MI2600's Avatar
Member# 3287
Relay Help Needed
I need a switched source of power for my console gauges.
My thought is to use a relay that is switched via the IGN terminal of the fuse block. Key on...power at IGN terminal...relay switch closes...power to gauges.
Anyone see any problem(s)?
Old 08-20-2006, 06:02 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Nope..
Although, If it's just gauges you probably don't need a relay..unless it is some type of special application you are going for. Current ~ Wise your draw is probably less than 5 amps.
  • 85 to 12 volts FUSED (1 to 3 amp) Switched power.
  • 86 to Hard ground.
  • 30 to the gauge panel.
  • 87 to a Hot at all times source (Via a fuse rated for the gauge panel draw)
  • 87a is not used.
That should do ya..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-20-2006, 09:07 PM
MI2600's Avatar
Member# 3287
Thanks, Doc.
You're probably right, but I thought I'd go from the relay to a junction block in the console and make all my connections from the gauges there. That way if I have to replace or change anything I only have to disconnect from the junction block and not doing any cutting/resoldering.
1980 TA choke relay jdcoic Electrical 17 05-16-2013 07:09 PM
68 charger lights T-bucket23 Electrical 5 08-14-2006 05:07 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Elec. fuel pump relay needed? upstand2 Electrical 4 05-10-2005 05:21 AM
Omg, Car Fire!! Malibu1980 Electrical 21 06-16-2004 12:34 PM
