The small wire feeding the starter solenoid. The terminal to which it is plugged, on the relay on the firewall of the car, shows 10.6 volts with key on. The other end of that same wire, at the solenoid of the starter, shows only 2.7 volts with the key on.
OK not sure what style of starter you have. If its the old style with the starter solenoid built on the top with the battery cable attached and then a small wire???
BUT, all that a side. If you have a wire and one end shows one voltage and the other end shows considerably less in a low current situation like this the wire/connectors are bad or there is something in between that you dont know about. The old style traditional starter with the solenoid on top do not need an external relay. Might be something to do with the conversion. As a Jaguar owner you will get pretty good at solving electrical problems ![]() Rich |
Starter
Doc here,
To Clarify... You have a Starter, mounted on the Block, with also a GM solenoid mounted atop it, and a "Ford Type" Solenoid mounted on the firewall?? Yes or no? If that's the case, I would say the layout will be as follows for each) From the battery to the solenoid, constant 12 volts, The big terminal (opposite side)going into starter, 0 volts (until energized) The "S" terminal (18 gauge) 12 volts ONLY when the key is in "Start" .. The "I" terminal (18 gauge) 12 volts (if ignition resistor not used, 6 to 9 volts if one is used) ONLY in "Start" position. If you are getting 12 volts in (on the big cable) and 2 volts out (on the other side to the starter) you have a loose connection, bad starter winding, or a bad ground at the starter motor. Check that. A Burned Starter solenoid contact (at either solenoid) will also cause the same problem. If you are just using a relay to control the "Start" Function, and you get 12 volts in and 2 out, it's a burned contact on that relay.replace Or bypass it. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
| 1980 TA choke relay | jdcoic | Electrical | 17 | 05-16-2013 07:09 PM |
| starting problems after MSD | SBC S-10 | Electrical | 4 | 07-18-2005 01:23 PM |
| READ ME: Bugfix for several related problems | Jon | Hotrodders Site Suggestions and Help | 3 | 04-17-2005 03:06 PM |
| Starting Problems... | arch | Engine | 12 | 10-30-2004 05:21 PM |
| TBI Starting problems | punk1c5040 | Electrical | 6 | 10-29-2004 06:20 PM |
