Relay place - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2009, 05:01 AM
V305's Avatar
On the Border
Relay place
Hi guys, just some questions, I wonder... what is the best place to install a relay? Should be close to the Acc (fuel pump, lights), close to the power source (switch, fuse, dash) or right in the middle?
Old 01-03-2009, 05:36 AM
From an electrical standpoint, it doesn't matter where the relay is physically located in the circuit. The relay is just an electrically operated switch to make and break the circuit. If you are installing a new circuit, make sure you are using wire that will handle the load (can't hurt to go a bit bigger, if it's a long distance). If it were me, I'd try to find a convenient place for the relay that would be easy to access, it case it ever needed replacement, and where it wouldn't be likely to get wet.
Old 01-03-2009, 01:00 PM
V305's Avatar
On the Border
Thanks, I'll consider the load and the access
Old 01-03-2009, 05:39 PM
Cape Cod Bob's Avatar
Typically relays are used to keep high current carrying wires out of the passenger compartment. At least thats the theory. Seems to me there is a lot that goes though the steering switch and comes into the fuse box. Which is in the pass. comp.
Old 01-03-2009, 06:02 PM
406 bug's Avatar
9.82 @ 139mph
I thought relays are use because many regular switches are not capable of hanlding the higher amp loads. I use 30 amp swithces at a cost of 3.95ea. rather than high dollar relays.
Old 01-06-2009, 12:20 AM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
The best uses of relays are to keep high currents out of the cabin, as Cape Cod Bob said, and to reduce power loss to the device being switched. If you are using 30 amp switches instead of relays, you have to mount the switch where you can reach it. This brings high current carrying wires into the cabin and it usually results in long runs of wire from source to device.
A couple of points to remember:
  1. You're dealing with a low voltage system. If you have a 2V drop, that represents almost 14%, given 14.5V from the alternator.
  2. High currents yield high heat when circuits get shorted.
A relay is more than a switch; it's a remote crowbar. You use low current to switch high current. Benefits:
  • lighter wires to controls, where space is usually at a premium,
  • reduced wear on switches,
  • ability to use a lower current fuse on each relayed control circuit,
  • much lower risk of fire in case of shorts in the cabin,
  • usually shorter runs of heavy wire from source to device,
  • less voltage drop to device, so it works better.
Just getting higher rated switches doesn't gain any of those benefits.
Old 01-06-2009, 06:58 AM
302 Z28's Avatar
Grouch nails it.
Vince
Old 03-29-2009, 02:42 PM
Wiki Edits: 85
I place relays at the most conveniently accessible safe location that keeps the load circuit as short as possible. Since the switching circuit is a very low load circuit, I don't worry about how the relay location affects it.
Horn Relay Chevy 84 Electrical 10 08-04-2008 02:31 PM
Please help! Radiator fan not working! billsbird Electrical 7 09-01-2007 03:49 AM
Welding a panel in place Quarter Flash Body - Exterior 6 03-22-2007 03:56 AM
Starter relay questions professor-patrick Electrical 13 08-23-2006 12:14 PM
68 charger lights T-bucket23 Electrical 5 08-14-2006 06:07 PM
