Relief Cuts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2010, 01:29 PM
Relief Cuts?
How do you determine where exactly to do this in order to have a smooth transition? Should you do it as you stitch or just make some before hand? How do you determine the distance between each one?
Old 12-11-2010, 03:15 PM
DanTwoLakes's Avatar
Wiki Edits: 22
You determine where relief cuts go when the fabric is binding where you are sewing two layers together. The tighter the turn, the more relief cuts you need to make, and the closer together they are. They only need to be far enough apart to keep the fabric from binding. There is no formula, a square corner only needs one relief cut, and a circle needs a lot of relief cuts all the way around.
oil filter pours oil LQQKING4U Engine 10 10-05-2009 01:53 PM
Snowmobile compression relief valve - how to cboy General Rodding Tech 12 11-09-2006 12:58 PM
compression relief valve for snowmobile engine cboy General Rodding Tech 13 06-04-2006 04:47 AM
2 Valve Relief vs. 4 Valve Relief Chevy21 Engine 4 12-02-2004 02:07 PM
Fahrenheit 9/11 part DOUX! 4 Jaw Chuck Hotrodders' Lounge 50 07-22-2004 03:46 PM
