Relocate rear view mirror - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2005, 10:40 AM
lluciano77's Avatar
I want to move my rear view mirror in my Camaro up a few inches.
What is the best way to remove it safely? Solvents?
What is the best adhesive to re-install it?
Old 07-02-2005, 09:44 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
Usually mine falls off when I hit it with my head doing interior work. They do make a rearview mirror adhesive kit that can be had at most automotive parts stores for a few bucks. Not sure how to remove it carefully though.
Old 07-03-2005, 01:34 PM
lluciano77's Avatar
I have seen the rearview glue on kits at the parts stores. I have heard they don't work.
Does anyone do this sort of thing on a regular basis? Is there someone you can ask that does?
Old 07-03-2005, 01:40 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Lluciano, get a good grip on it and pull. it will come off. get the little kit for remounting rearview mirrors, it's in a little plastic blister pack. i've had better results with it than the cheapo mirror adhesive. it's probably the same thing... but i've not had to reattach my mirror since i used the more costly stuff. and more IS NOT BETTER. get it where you want it, and use a piece of tape to hold it in place and allow to dry there overnight.
Old 07-03-2005, 08:09 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Any glass shop or the a dealer has mirror attachment kits. Not very expensive. Just make sure you have it where you want it, before you permanently attach it.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
79 trans am rear discs busterbuddie Suspension - Brakes - Steering 7 01-20-2005 10:58 AM
79 trans am rear discs busterbuddie Suspension - Brakes - Steering 2 01-10-2005 07:29 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 05:42 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
