Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - relocating spring perch
Old 08-29-2012, 05:40 PM
runn141's Avatar
runn141 runn141 is offline
i have a rear end that is 1 1/2 over more on the driver side from the other. would it hurt having the pinion out of line with the transmission 3/4 of an inch to the passenger side? if i move them that much to line the wheels up? it is a rear with factory disc brake from a 2wd s10 blazer. the original rear is in perfect alignment where with the blazers is over 1 1/2. so it isn't the frame of the truck im using.
