-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   relocating spring perch (http://www.hotrodders.com/forum/relocating-spring-perch-223514.html)
runn141 08-29-2012 06:40 PM
i have a rear end that is 1 1/2 over more on the driver side from the other. would it hurt having the pinion out of line with the transmission 3/4 of an inch to the passenger side? if i move them that much to line the wheels up? it is a rear with factory disc brake from a 2wd s10 blazer. the original rear is in perfect alignment where with the blazers is over 1 1/2. so it isn't the frame of the truck im using.
BOBCRMAN@aol.com 08-29-2012 08:19 PM
Won't hurt at all. Ford Motor Co. did it for many years..
