relocating spring perch - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2012, 06:40 PM
runn141's Avatar
SB S10
i have a rear end that is 1 1/2 over more on the driver side from the other. would it hurt having the pinion out of line with the transmission 3/4 of an inch to the passenger side? if i move them that much to line the wheels up? it is a rear with factory disc brake from a 2wd s10 blazer. the original rear is in perfect alignment where with the blazers is over 1 1/2. so it isn't the frame of the truck im using.
Old 08-29-2012, 08:19 PM
BOBCRMAN@aol.com's Avatar
Won't hurt at all. Ford Motor Co. did it for many years..
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
runn141 (08-29-2012)
Rear Spring Perch Kit 345 desoto Transmission - Rearend 4 09-20-2008 12:14 PM
spring perch bolts chopperxkustoms Suspension - Brakes - Steering 4 06-23-2006 06:21 PM
spring perch no welding needed ??? Can drive 55 Transmission - Rearend 1 10-07-2005 08:36 PM
67 camaro spring perch fork Suspension - Brakes - Steering 1 03-24-2004 04:45 PM
'68 firebird spring perch distance firebirdmi Transmission - Rearend 0 02-07-2004 05:05 PM
