Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - relubing cam from lifter valley
Old 07-08-2010, 07:57 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Instead of doing so I recommend priming it when she`s ready to fire off. Make sure you use oil that has ZDDP and some STP oil treatment, also make sure the oil filter is prefilled. Prime on it until it has oil coming out of the rockers. After it fires do the normal break in routine of 20 minutes and vary the RPM from 1800 to 2200.
