Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - relubing cam from lifter valley
Old 07-09-2010, 07:17 AM
curtis73's Avatar
curtis73 curtis73 is offline
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Just FYI... prelubing things by spinning the pump does absolutely nothing for the lobes. All you'll be doing is oiling the cam bearings and upper valvetrain. Cam lobes get absolutely no oil from pressurized sources - only from crank splash. You can spin the pump all day and not lube the lobes.
