Instead of doing so I recommend priming it when she`s ready to fire off. Make sure you use oil that has ZDDP and some STP oil treatment, also make sure the oil filter is prefilled. Prime on it until it has oil coming out of the rockers. After it fires do the normal break in routine of 20 minutes and vary the RPM from 1800 to 2200.
If you have the int. manif. off then by all means pour some cam break-in or oil down through there...but as DV said still pre-lube the engine just before you fire it.
Just FYI... prelubing things by spinning the pump does absolutely nothing for the lobes. All you'll be doing is oiling the cam bearings and upper valvetrain. Cam lobes get absolutely no oil from pressurized sources - only from crank splash. You can spin the pump all day and not lube the lobes.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
