Remanufactured Steering Gear Problem? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2012, 08:52 PM
Silver Surfer's Avatar
Advanced User
Last journal entry: Test Drive (finally)!
I got a remanufactured power steering gear from LMC for my 81 Chevy truck. I got the thing on tonight and there is a definite drag/friction at dead center. Is this supposed to help you find dead center and eventually smooth out with use? Or is this an indication the thing sat around in the warehouse too long and some corrosion built up on the worm drive? Either way, do I need to exchange it?
Remanufactured crankshaft ?? wmwise Engine 10 10-30-2011 05:31 PM
GM Remanufactured Engines? mannyandlily Hotrodding Basics 17 11-06-2010 02:28 PM
converter with remanufactured trans fiolater Transmission - Rearend 1 03-31-2008 01:24 PM
Where do I find Remanufactured 6 Cyl Engine sifua Engine 1 07-06-2004 06:27 AM
remanufactured holley 65galaxie500 Engine 1 10-26-2002 06:58 PM
