Remeber those subs I bought? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2005, 12:15 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
I showed you guys this picture about two months ago.
Remember I bought all that stuff for $300 but I didn't know how to hook it up? I got everything installed around mid May. It was really easy to do. It took me about two weeks to blow the coil in one of those 3 year old infinity subs. So I bought two new Infinity 1040's. They sound great. It's pretty cool when my side view mirrors are vibrating. Here's what everything looks like installed.
Old 07-03-2005, 12:36 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Nice setup dude.
God, I"m bored today. Sure is cool not to have to go to work tomorrow... and get paid anyway.
K
Old 07-03-2005, 02:49 PM
Nos's Avatar
Nos Nos is offline
i have the same amp..
lol its not hard to install..
run your power wire from ur battery..
tap a blue wire (rem wire) in ur wiring harness with the blue wire with a white stripe.. then to the amp..
and at the same time your input and out put wires from ur amp.. look like 2 plugs.. ones usually white and others red..
then ground your amp..with black gound wire
then hook ur subs up to + - and + -
nice setup..
i had 3 subs in my beretta gt.. 2 mtx 10" subs in a slotted box.. plus 1 rockferd fosgate 15" and a closed box .. off one alpine 700 watt mono block amp.. and my mp3 alpine deck
Nos
N|O|S
Old 07-03-2005, 02:59 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
do you happen to know what Ohm rating those subs are?
Or if the amp is 2 Ohm or 4 ohm stable?
I may be able to safely double the effective amperage of your system with that info.
Old 07-03-2005, 06:34 PM
Ghetto Jet's Avatar
http://caraudiosecurity.com/shop/pro...s_id/3838.html
NSX, there are the specs on my sub woofers.
In the manual for the amp it gives watt ratting per channel at 2 ohms and 4 ohms so I guess it's stable at both.
Old 07-03-2005, 07:59 PM
NXS's Avatar
NXS NXS is offline
That amp has the ability to power 4 of those subs.
If it is 2 ohm stable bridged hook them up like the top pic and if not you can hook them up like the bottom diagram. The downfall to the bottom diagram is that you need four speakers...which could be a good thing if you've got the greenbacks>
Old 07-05-2005, 01:38 AM
Malibu73's Avatar
'68 Chevelle Malibu Sedan
I thought you drove a caprice?
Btw, NICE SUBS!!!
That capacitor must make it really easy on your battery.
Old 07-05-2005, 02:21 PM
malc's Avatar
Living At The Speed Of Life
Do they blow the trunk open at full bore ?
Old 07-05-2005, 06:44 PM
Ghetto Jet's Avatar
Btw, NICE SUBS!!!
I have two Caprices, I drive them occasionally, the Honda is my primary. I drove a little over 30,000 miles in the last year and I don't want those miles on the Chevys.
Old 07-05-2005, 06:46 PM
Ghetto Jet's Avatar
Nah Malc they aren't that potent. That trunk is pretty stiff though.
Old 07-05-2005, 07:39 PM
NXS's Avatar
NXS NXS is offline
Try hooking the subs parallel to each other, then bridge them to the amp, like the upper drawing i showed you {your amp should say which terminals will bridge it}.
Because the Ohm rating {resistance} is cut in half and the voltage stays the same wattage will double.
If you have an AC volt meter I can tell you the real Wattage of the amp also.
Old 07-05-2005, 07:52 PM
Ghetto Jet's Avatar
NSX, I'll see what I can do with it tonight, thank you for the helpful diagram.
Old 07-05-2005, 09:36 PM
Ghetto Jet's Avatar
NSX, I have a little problem. My amp only has one positive and one negative source for the subs. Your pictures show that I need two of each to make it work.
Old 07-05-2005, 10:12 PM
NXS's Avatar
NXS NXS is offline
Is this amp mono? {i don't mean the STD silly!}
If it is it's just fine.
Just hook both + to the + & both - to the -.
Old 07-06-2005, 09:22 AM
Ghetto Jet's Avatar
yea it is a mono amp.
I bought a MIG daimon1054 Garage - Tools 7 04-15-2005 04:57 AM
Bought a new car RCastle Hotrodders' Lounge 4 11-14-2004 02:52 PM
Just bought a 47 Ford Tudor sedan DANP Introduce Yourself 4 10-15-2004 12:39 PM
I bought a new car! Adrenaline_Fiend Hotrodders' Lounge 16 11-22-2003 06:45 PM
Just bought a 400 thanks to all you guys who helped me stonedchihuahua Hotrodders' Lounge 4 12-01-2002 04:59 PM
