for the price you are going to have to spend to install the remote battery you could just as well rebuild where it goes.
You will need a battery box mounted in the trunk area 0 or 00 wire plus connectors then you can go two ways one groung the battery to the frame and then pick it up at the other end of the frame to the motor but you still have to run the postive cable to the front. Two run both cables to the front. I would add up the cost for the thing you will need to move the battery and then add up what it will cost to replace what is messed up on yours now. I install second battery systems for sterios all the time and use gelcell batteries.total is around 250-350 depending on the connector and which wire the customer picks(ie.standard 00,gold 00, plus the mfg of the wire.) hopes this give you something to think on. let me know what you want to do |
If there was enough left up at the original place for the batery i would just rebuild it, hell that was my first idea till i took out the batery and seen just how bad it was!
The way it is set now is + goes to the starter and the - goes to the altinator bracket and a small lead going to the body. If i can get away with just running one wire that would be ideal, however im not sure if the grouning will work. I believe my car is a uni-body car, it uses a subframe for the engine. the subframe is mounted on rubber bushings, so would i have to run a wire from Batery, to car frame, to sub-frame, to engine block? and with all these connections wouldn't the resistance get higher and higher with each connection? ill be doing a votage drop test once and when these gets done anyway to make sure everything is OK for the positive side how and where would i run that wire? would it be wise to run it inside or outside the car? If i run it ouside what kinda protection do i have to have for the wire agenst road debris and exhaust heat and other things? thx for your help again Camaro76 |
I like meanmachine's idea of new tray, rebuild area, still alot less expensive than running cables from back to terminal. If you put it in the trunk I recommend a shut off switch and jumper terminals. I like the looks of the cleaner engine compartment but also need trunk space. Recently moved mine from trunk to under fender well. Good luck |
im not to worryed about trunk space or realy the cost so much, if i had a way to show you what im talking about im sure most of you would agree i should just no drop money and rebuild and just relocate, its pretty bad up there, the batery as iss just kinda sits in a little cranny where the bater was supost to be, the radiator, headlight asembly fender and a bar is onlthing holds it there, 1/4 of the tray exixts still.
why would i need a kill switce, jumper terminals and all that for a relocation, im not raceing this thing anywhere, just need a more secure place for the battery, what gage wire to i need? what would be the easyest way of running the wires? do i realy need jumper terms, kill switch, ect? do i run inside, or outside the car? trunk space is not realy that important, cost will be dealt with, easy to do and reliablity of job is key thx Camaro76 |
There is a kit that you can buy from Summitracing.com and it gives you enough wire to go from front to back. It's about 40 dollars.
Well, sounds like the trunk is a good place for your battery. I would install a shut off switch (not kill switch) at a convienent location (not in the trunk) just in case my wires started smokin I wouldn't have to fiddle for right key to open trunk, a battery box and cover to shut off power. Jumper contacts up front so if you do have to jump it jumper current doesent have to travel as far, can't jump thru a bad battery. Switch and Terminals are probably about $20. If your wires are in as bad of shape as you say the rest of the car is, I'd spend the extra bucks for it. This is only my 2 cents and only meant to be helpful and I hope it is. Good luck
