Remote Brake Booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2012, 01:24 PM
Last journal entry: Have to start somewhere...
I am currently working on restoring a Divco (milk truck).
From the factory it came with a single pot master cylinder and a hydrovac booster. I have no desire whatsoever to run a single pot master so I'd like to swap it over to a dual circuit. The problem is that where the master cylinder bolts up is really tight for space. There is just enough room for the master cylinder itself and definitely no room for a booster bolted directly onto the cylinder.
The truck doesn't, and won't, have power steering so a hydroboost is out. I thought about running it unboosted but the truck weighs 5,000lbs so that doesn't sound like a great idea.
Does anyone know of a remote mounted dual circuit vacuum brake booster I could use?
Thanks!
Old 07-13-2012, 05:16 PM
Cape Cod Bob's Avatar
Master Power Brakes Has one but only does the front.
Old 07-20-2012, 10:51 AM
Master power brakes has a dual circuit as well don't no the cost but you'll need 3 master cylinders I've not run one my self but it looks pretty slick.
making a remote fill brake reservoir Ed ke6bnl General Rodding Tech 6 01-20-2013 07:32 AM
need remote booster help Don Meyer Suspension - Brakes - Steering 4 08-21-2010 06:28 AM
Remote Power Brake Booster - 62 Impala Wagon glide85 Suspension - Brakes - Steering 12 12-24-2009 09:18 AM
remote brake reservoir fill HOT 'N' HVY Chevy Suspension - Brakes - Steering 2 11-06-2006 05:25 PM
I need a remote power booster nprfan Suspension - Brakes - Steering 10 10-20-2005 02:08 PM
