Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Remote breather/oil fill, any ideas?
Old 07-18-2007, 03:29 PM
hyarbour hyarbour is offline
re: Remote breather/oil fill, any ideas?
Depending on your installation. How about putting in an oil cooler and adapter, then you could tee into that with a check valve between that and your reservoir.
You could also just go with a bulkhead tube fitting directly into the oil pan.
