Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Remote breather/oil fill, any ideas?
Old 07-19-2007, 11:09 AM
Tech @ BG Tech @ BG is offline
Technical Support Barry Grant
You wouldn't want to put a breather on the dip stick tube since there will crankcase pressure.
The simplest way to do this would be to run a hose to one of the 3/8" pipe plug above your oil filter to use as a filler hose.
Then you would attach your cannister to the back of your valve covers (this is common on race engines) this is where you'll attach your PCV valve.
