Remote Control Light Switch? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2011, 07:58 PM
Semper Gumby
Wiki Edits: 2
I am looking for a simple on/off light switch with a remote.
My Garage/shop is just about 100' from the house.
I have outside floodlights on the shop.
They are controlled by a switch inside the back door of the shop
HOWEVER - it would be VERY nice if I could turn those lights ON when leaving the shop for the night (so I can see what I am about to trip over!) and turn them OFF when I get to the house. (And turn them ON from the house if I am going to the shop after dark.)
Yes I could bury a wire and install 3-way switches, but other factors make this impractical. Therefore I am looking for a remote-controlled light switch that will work at a range of 100 feet plus, and I do not need it to include a dimmer.
Since garage door openers work at ranges longer than that, I can't help thinking that is shouldn't TOO difficult or expensive to do, and I suspect that I am not the only one to want such a thing
Has anyone come across such a thing?
Basically (as I imagine it to be) it is just a wall-mounted switch that has a RF receiver built in to toggle back & forth between off & on
Old 04-15-2011, 10:56 PM
sqzbox's Avatar
My pipes are my music
Most people use a motion sensor activated flood light system. You move in or out of the garage and they come on for a period of time and you can set the sensitivity of the motion detector. You can also check out a home center for remote light systems. I know they have them because ADT security has remotes for home use. Good luck.
If you have bigazz hands, you can always buy a Clapper!
Old 04-16-2011, 08:40 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I've seen lots of remote controlled switches and outlets, but none I've seen work beyond 60 feet.
Old 04-16-2011, 09:48 AM
sqzbox's Avatar
I like the motion sensor system the best.
Goes on and off automatically.
Anyone that has no business being around the garage will get lit up so there's no need for night vision scope on the rifle.
Old 04-16-2011, 09:59 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
^^^^^^^^^^x2
Old 04-16-2011, 10:44 AM
75gmck25's Avatar
I converted all my flood lights to motion sensor activation, and I just leave them on. The sensors for the lights above my driveway area use a two stage system. For the first four hours after dark they come on at about 1/2 power to light the driveway. If anything activates the sensor they go to full power. The sensors on the back of the garage just use the single stage motion sensor.
Complete light kits, or add-on sensors are sold at Lowes, Home Depot and Wal-Mart. There are 180 degree and 240 degree sensors (use on the corner), and some sensors have the two-stage light-saver mode I mentioned above. Most of them are Zenith or Honeywell brand.
There are also remote RF light switches, but you would probably have to find them online. I have not seen them in the local stores.
bruce
Old 04-16-2011, 12:47 PM
I bought a plug in reciever w/ remote you can plug other things to. Got it to light up some decorative yard lights. Didn't work worth a dam. Living room window's about 30 feet away from it and I had to stand on my tiptoes to get it to work, sometimes. Finally chucked it.
1967 Mustang Coupe remote mirror control location. 67Mustang Al. General Rodding Tech 15 06-30-2010 05:17 PM
Fan Control Switch 74vetteman Engine 5 12-15-2009 12:35 PM
ABS and Traction control light jrm123180 Suspension - Brakes - Steering 1 10-12-2009 07:45 PM
Remote Kill Switch... AmericanPackMule Electrical 5 09-23-2008 08:03 AM
Help with diagram for remote door control jjl Electrical 4 05-30-2007 03:39 PM
