Remote cup gun OK for frame painting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2005, 10:37 AM
Barrybomb's Avatar
Registered Loser
Somehow,I seem to be moving backwards,but I am going to be painting my open car trailer before I get to the car.I'm going to have it blasted next week.Deal is, he sandblasts(with commercial 500 CFM rig),I paint.I haven't painted in about 5 years,and even then was an amateur,but atleast I have the intentions of doing the best job possible. I'm planning on going with 2 coats of SPI epoxy,then topcoat with 2 coats of an acrylic urethane like Deltron, (DCC, not a base/clear system).I want to go with a silver metallic on this thing.I'm open to suggestions on the paint,I'm looking for durability and chip resistance more than anything.Also,should I treat the surfaces that will see abuse differently,for better durability(coat with clear?)
Is there anything I should do prep wise after the sandblasting?He's going to thoroughly blow the thing off after and with 500 CFM he should have it very clean.Can I get to it right away with the epoxy? I'll be painting outside as soon as he is done.
I want to use a remote cup gun.I figure that is the best way to get the paint everywhere.The gun I have is atleast 10 years old, I don't think it is HVLP.I know that everything is gravity feed now,will the remote cup gun be OK?
I know that this is only a trailer,but with all the prep work involved in any project, I don't see the sense of short cutting on the material or the equipment.After this project I'll move onto the real thing,But for now it's good to get my hand back into it with this.
Old 05-17-2005, 01:20 PM
BarryK's Avatar
Remote gun = Pressure pot??
If it is that will be no problem.
Clear will be your best protection.
Silver base I would say Diamont (Basf) would be most forgiving for a beginner with out getting into the premium brands.
Old 05-17-2005, 04:43 PM
Barrybomb's Avatar
Registered Loser
Thank you Barry,yes a 2 quart pressure pot.The challenge is that After it is blasted I will have about 5 hours tops to get this thing sprayed before I am kicked out and required to pick it up the next morning. I'll be spraying outside.Does this give me enough time for Base/clear?This is one reason I was figuring on single stage urethane.Also,what would be the differences between the BASF verses the "premium" paint.
Old 05-17-2005, 05:23 PM
BarryK's Avatar
With the pressure pot you can move and outside will be good for epoxy but not for base/clear.
Shoot one or two coats of epoxy and wait 60 minutes than single stage.
and outside I would try and find a polyurethane so check with Napa or a Sherwin Williams jobber.
You will have enough time and don't do no rain dances, for sure.
Old 05-17-2005, 05:44 PM
Barrybomb's Avatar
Registered Loser
Barry,what kind of characteristics are the polyurethane paints going to have that are going to benefit me on this job?Will they be OK in metallic?How many coats should I figure on for durability?
P.S.- I don't plan on dancing in my Tyvek suit,Not cool!
Old 05-17-2005, 05:50 PM
BarryK's Avatar
Polyurethane is going to be the most durable BUT metallic spraying of a poly is no child's play unless its a small amount of metallic or real fine.
Two coats of a poly or urethane should do it.
Any U-Tech 200 around there? Sold by Sikkens jobbers.
Worth a check.
Old 05-17-2005, 06:04 PM
Barrybomb's Avatar
Registered Loser
I know of a local Sikkens jobber,I'll check.What is it about this stuff that will turn me on?
What should my concerns be about shooting the metallic?
How should I set up my gun?Will the same setup work for the epoxy and the topcoat?
Old 05-17-2005, 07:27 PM
BarryK's Avatar
The 200 is a very tough acrylic urethane and has very good metallic control.
this paint use to be a polyurethane but was referred to as acrylic as not to scare the painters. When Sikkens bought company in 99 changes were make but its still pretty good. It used to be skydrol approved most likely not know.
1/2 the price of Concept, easier to spray and stronger.
mixes 3:1:1 and since outside use a slow reducer.
setup will get you through it.
Old 05-17-2005, 08:49 PM
Barrybomb's Avatar
Registered Loser
Thanks Barry.What size tip should I shoot with? What cleaning procedure do you recommend between products?
I am I able to go staight to epoxy after the sandblasting/blowoff operation?Is there any additional prep?
2 coats and 2 coats and I should be fairly bulletproof?
"Basic of Basics" How do I paint my car myself? Centerline Body - Exterior 5 11-07-2011 07:14 AM
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
harbor freight hvlp gun jn0w Introduce Yourself 2 06-15-2004 03:08 PM
