Remote Master Fill - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2007, 05:59 AM
joeford's Avatar
36 Dream
Remote Master Fill
I have a frame mount booster and dual master cylinder and would like to install a remote firewall fill to the 36 Ford Coupe.
I note that remote kits include a new master cylinder. Is there a way that I can use my master cylinder (since it's brand new) and add the remote fill?
Another words has anyone out there ever done this?
It would appear that I could tap a whole through the frame mounted master cylinder cover and come up with a through the cover fitting that would allow me to run a line up the firewall.
Anyone make the parts for such a conversion?
Old 03-20-2007, 06:07 AM
Will I ever get it done?
Last journal entry: Hood
There is an outfit out there that makes a billet cover for the GM master cylinder designed for a remote fill resevoir. I can't remember who and I can't find it now. Google it. If no one else responds and you can't find it, I will look tonight after work when I have more time. I know I have it book marked.
Old 03-20-2007, 09:07 PM
Here's one:
http://www.streetrodstuff.com/Products/76/
Item #434 on this page:
http://www.kugelkomponents.com/pricelist.php?ID=6
Old 03-20-2007, 09:45 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
mid-fifty f-100 parts sells them for the under floor boosters we put on our old fords. I don't know if they would fit other ones though. At least they are out there.
If you can't find what you need elsewhere, give them a call. Who knows, it might fit.
http://www.midfifty.com/
remote brake reservoir fill HOT 'N' HVY Chevy Suspension - Brakes - Steering 2 11-06-2006 05:25 PM
Bleeding a Clutch master & slave Bryan59EC Transmission - Rearend 5 08-03-2006 06:16 PM
where to find a replacement remote fill master cylinder low57 Suspension - Brakes - Steering 1 03-24-2006 04:13 PM
Remote Fill Master Cylinder trifivefan Suspension - Brakes - Steering 1 08-29-2005 05:29 AM
Remote Shut Off Switch doesn't shut it off! F-1Rodder Electrical 2 05-01-2003 04:01 PM
