-   -   Remote Power Brake Booster - 62 Impala Wagon (http://www.hotrodders.com/forum/remote-power-brake-booster-62-impala-wagon-135614.html)
glide85 03-23-2008 06:26 PM
Anyone have any experience installing a remote power brake booster? I am thinking about purchasing one from ECI (Engineered Components) and putting it on my 62' Impala Wagon. My only experience has been with one like a Midland, etc. that is commonly used on street rods. Any advice will be appreciated. Thanks!
Deuce 03-23-2008 07:25 PM
Never installed one on a 62 Chevrolet but I have used their products and kits before without problems. I used their stuff on pre WWII type of vehicles.
glide85 03-23-2008 07:47 PM
Thanks. Its good to know their products are quality.
Bad Rat 03-24-2008 08:49 AM
I used a remote booster , off of a motor home , on a 39 chev,, with no problems,, just make sure you have it connected to the proper vacuum supply,
Is this with a aftermarket brake set up, or stock?
trees 03-24-2008 04:24 PM
I used a small one from ECI on my truck for years. Worked great. It was mounted on a bed cross member about 5 or 6 feet from the vacuum source and about 3 feet from the master cylinder. Installation instructions were with it.
Trees
glide85 03-25-2008 08:52 AM
Thanks for the advice. I am using a Kugel Components master cylinder which I was able to put under the dash in order to clean up the firewall. I am running an LS1 for power and a "stock" master cylinder and booster would not have cleared. If anyone is interested in using a Kugel master cylinder such as this, let me know. I can help.
Bad Rat 03-25-2008 11:00 AM
I went out and looked in my parts pile,, and found a small midland remote booster that were used on motorhomes, its about 7" in diameter, I'm not sure exactly what it came off of,, but I could take some # off of it to find out,, and cross referance,, if you are interested?
It would be perfect for what you are doing,, Bill
glide85 03-26-2008 09:50 AM
I am very interested. Thanks for your help. You can just email me the photos if you want and give me an idea how much you want for it. I assume it has been out of the weather.
Bad Rat 03-26-2008 11:44 AM
1 Attachment(s)
The one on the left is the small one,, probably 7" numbers are C [possably a 0 ]3395 other is 8" number 30 C [possably a 0] 007
glide85 03-26-2008 12:05 PM
The one on the left is single line, correct?
Bad Rat 03-26-2008 01:48 PM
Yes it is,, I never paid attention to that,, probably wouldn't work for your needs,,it was used on a 50 chev woody, appairently it was plumbed into a single line, NOT a good idea ,, don't recall exactly how it was setup,, :confused: Bill
Dragwagon62 12-23-2009 09:48 AM
Any help would be appreciated
I would appreciate any help you would be willing to help me with on the conversion swap in your 62. I am planning on dropping an LS3 into my 62 Impala 2 door hard top and would like suggestions and or comments on some of the issues you went through to get it done. I definitley like the idea of cleaning up the engine bay and stuffing the master cylinder away and using a remote brake booster.
glide85 12-24-2009 09:18 AM
Help with your LS3
Just send me an email at rschollmeyer@email.com and I let me know what issues you are interested in addressing on your swap. Good to hear someone else is putting an LS motor in a 61-64! Take care.
