remote power steering canister? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2011, 12:10 AM
I currently have a march performance remote power steering reservoir. I believe it is about 6 inches long and I have it bleed for the most part but just a little whine still. I have seem another similar set up on a impala and his reservoir was bigger in diameter and longer. I only saw it and was not able to ask him if he did a switch to bigger. I am guessing my reservoir is to small and causing the fluid to be just a little too low during operation. I cannot fill anymore otherwise it will blow fluid out while running when u turn. Fluid rises in one direction say turning left and decreases in the other direction say turning right. Has anyone else had this problem and had to switch to a bigger reservoir because of bleeding the system and eliminating any whine or bubbles for good.
remote steering reservoir opinion use2teech Suspension - Brakes - Steering 2 09-02-2009 04:30 AM
I need a remote power booster nprfan Suspension - Brakes - Steering 10 10-20-2005 03:08 PM
power brake booster vacuum canister?? Ed ke6bnl Suspension - Brakes - Steering 1 10-21-2004 05:33 PM
Help! How do I install a new power steering canister to my existing pump? boricua_stang Suspension - Brakes - Steering 1 10-02-2003 07:48 PM
Remote reservoir power steering V8 S-10 Suspension - Brakes - Steering 1 09-17-2003 06:51 PM
