remote reservior - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2013, 07:03 PM
jan bogert's Avatar
LARGE TOY BOX
remote reservior
i have a remote fill master cyl. i would like to know if the 4oz. remote filler reserviors are alright, or are there alot of no's about useing them. i don't have alot of room on my 33 willys, but i don't want to be sorry i didn't go larger. all comments welcome. JAN
Old 05-11-2013, 07:59 PM
life is a temporary assignment
Should work find,,, Once everything is full, It's done.. unless you have a leak..
Old 05-11-2013, 10:04 PM
sedanbob's Avatar
Mine is probably about 4 oz - works fine.
Old 05-12-2013, 05:53 AM
jan bogert's Avatar
LARGE TOY BOX
Hi Bob, i see u have just one, does that run both front and rear? i'm going to use two, one for each, in case one set of brakes goes out i still have brakes.
Old 05-12-2013, 08:15 AM
sedanbob's Avatar
I have a dual master, but the lid is not divided so the single reservoir can fill both. If one side of the system leaked, the other side would still work because of the reservoirs built into the master. Some of the lids, depending on your master, have two fittings, mine has one. If you are using a master that does not have built-in reservoirs, you would definitely need two remote reservoirs.
Hydraulic Clutch reservoir - remote or not remote if possible? ClassicDriver Transmission - Rearend 6 03-09-2010 05:40 AM
remote reservior goshawks00 Suspension - Brakes - Steering 7 05-14-2008 02:42 PM
Hose from reservior to PS pump guba_unus Suspension - Brakes - Steering 5 08-10-2005 07:19 PM
remote battery, remote disconnect for fuel pump questions. Jared Engine 1 03-16-2004 10:33 PM
Remote Camaro76 Electrical 6 01-10-2003 06:20 PM
