Remote Reservoir Alternative to '74 Corvette M/C - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2011, 05:03 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Clutter
My ride uses a '74 'Vette M/C located under the floorpan, a very inconvenient place to access and check on a regular basis.
Is there a remote reservoir alternative I can get at NAPA?
Old 05-21-2011, 02:00 AM
staleg's Avatar
Last journal entry: Hand brake
Not at Napa, but Kugel Komponents make a MC cap with attachment points for remote inspection reservoirs. This way you are able to make the inspection reservios very small, since you still have the main reservoir on the master.
(the rest of the pedal setup is home made, not Kugel)
I bought two small reservoirs inteded fror the rear brakes on a Suzuki R1000 motor bike and placed them at the fire wall:
Old 05-21-2011, 03:31 PM
hduff's Avatar
Thanks for the response.
From their site:
http://socuteurl.com/bumblebee
#5581701 Aluminum Remote Style M/C Cover Only For Corvette Cast Iron M/C. Includes aluminum cover with 1/8 npt and gasket. $40.00 plus new M/C plus remote reservoirs.
And PRC also makes as remote M/C kit.
http://www.streetrodstuff.com/Products/76/ $150.00
I was aware of those. I'm looking for an OEM replacement that uses remote reservoirs.
Hydraulic Clutch reservoir - remote or not remote if possible? ClassicDriver Transmission - Rearend 6 03-09-2010 05:40 AM
remote steering reservoir opinion use2teech Suspension - Brakes - Steering 2 09-02-2009 03:30 AM
Remote reservoir positioning ? cboy Suspension - Brakes - Steering 14 03-15-2008 12:18 PM
Remote Master Cylinder Reservoir ratfink35 Suspension - Brakes - Steering 6 12-28-2007 12:24 PM
Remote reservoir power steering V8 S-10 Suspension - Brakes - Steering 1 09-17-2003 05:51 PM
