Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Remote reservoir positioning ?
Old 03-14-2008, 10:00 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Originally Posted by cboy
does the reservoir always have to be higher than the master to gravity feed?
Because the remote reservoir is gravity fed; it must be above the master.
If the reservoir is removeable, you might be able to mount it under the dash and above the clutch master connecting it with tubing.
Have you considered lowering the clutch master on the firewall and just changing the linkage from the pedal? This way you would not have to change the pedal location.
