remote selinoid - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2010, 10:35 PM
remote selinoid
had headlight problems, low voltage, and starter wasn't real strong on my 78' GMC Cabellaro pro/street. went with ford remote selinoid, did away with fusible links and just wired in inline fuses to the two wires which is one to ignition switch the other to headlights as a 78' uses no headlight relay. problems gone!! so guys get those wires away from that header heat and have less troubles.
Old 06-27-2010, 01:04 PM
302 Z28's Avatar
Solenoid
Vince
Hydraulic Clutch reservoir - remote or not remote if possible? ClassicDriver Transmission - Rearend 6 03-09-2010 05:40 AM
How to make remote starter 350pano Electrical 8 05-12-2009 05:22 PM
Manual remote mirror on caprice. Loose adjustment. 973kgt General Rodding Tech 2 01-07-2009 07:29 AM
3 Function Remote 35olds Electrical 4 02-03-2007 01:44 PM
Remote solenoid: problem starting the engine darom Engine 9 03-21-2004 12:04 PM
