Remote Solenoid Install problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2004, 04:33 PM
New Member
Hi,
I just finished installing a ******* solenoid in my Chevy to help out with my hot start problems. I used the schematic at Novaresource.org
Now I have no power anywhere to the vehicle. If I hook up my remote starter to the "A" and "S" terminals the engine will crank and attempt to fire until I let go.
Did I make a bad connection somewhere along the way? Any suggestions?
Thanks a lot,
Ron
Old 01-12-2004, 05:49 PM
do it this way
If I had a dollar for all of these I installed on the old 6 volt cars I could go on a cruise. That is a bad wiring diagram. If you will wire it like this it will work. The problem is not that you don't have 12 volts from the Batt. to the starter thru the batt. cable it is that you do not get the full 12 volts thru the wires to the solenoid pull in coil. Hope this helps
rock
Old 01-12-2004, 06:20 PM
New Member
Got it
Got it going, 1 small mistake on my end. Thanks for the help!
Ron
