-   -   Remote Start (http://www.hotrodders.com/forum/remote-start-106714.html)
jor 01-14-2007 11:29 AM
Remote Start
1 Attachment(s)
I want to do a compression check on my 87 Suburban (everything stock, 350, automatic, 4wd) but I'm not sure how to hook up my remote starter. I usually work on older stuff like my Ford pickups. Anyhow, my remote starter is the common kind with two leads. On my Fords, I put one on the hot battery terminal and the other on my starter solenoid. Here's a photo of my remote starter. Thanks.
jor
vicrod 01-14-2007 11:58 AM
Connect (1) lead of the remote start button to the S terminal on the starter solenoid. A purple wire will be connected to the S terminal and is on the block side of the solenoid.
The solenoid is located on the starter itself.
Connect the other lead to the battery + terminal.
vicrod
jor 01-14-2007 01:20 PM
Thanks, Vic. This Suburban was my son's and now I have it back so I thought I'd play around with it a bit.
jor
