Remote Start - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2007, 10:29 AM
jor jor is offline
Remote Start
I want to do a compression check on my 87 Suburban (everything stock, 350, automatic, 4wd) but I'm not sure how to hook up my remote starter. I usually work on older stuff like my Ford pickups. Anyhow, my remote starter is the common kind with two leads. On my Fords, I put one on the hot battery terminal and the other on my starter solenoid. Here's a photo of my remote starter. Thanks.
jor
Name:	Remote Starting2.jpg
Old 01-14-2007, 10:58 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Connect (1) lead of the remote start button to the S terminal on the starter solenoid. A purple wire will be connected to the S terminal and is on the block side of the solenoid.
The solenoid is located on the starter itself.
Connect the other lead to the battery + terminal.
vicrod
Old 01-14-2007, 12:20 PM
jor jor is offline
Thanks, Vic. This Suburban was my son's and now I have it back so I thought I'd play around with it a bit.
jor
64 Impala Remote Start Question EazyDuzIt102 Electrical 2 06-27-2006 09:51 PM
87 Bronco doesn't start kgm656 Engine 2 05-30-2006 02:00 AM
small block chevy cold start problem bennett Engine 7 04-09-2006 11:44 PM
Remote Start Schroeder351M Hotrodders' Lounge 2 07-12-2004 11:18 AM
Remote solenoid: problem starting the engine darom Engine 9 03-21-2004 12:04 PM
