remote start - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2004, 11:46 PM
texasfinest1's Avatar
remote start
Does anyone here know how to add a remote start alarm to a car without fuel injection? I want to add one to an 87 caprice but people tell me I can't. I have a friend who has one on a 83 cutlass. I would would ask him but he bought the car with it on there already.
Old 08-06-2004, 01:23 AM
club327's Avatar
What's a remote start alarm? Is it an American thing?
Old 08-06-2004, 02:09 AM
If the car will start cold without setting the choke, it should work. If not, there was somebody talking about adding some sort of solenoid to kick the throttle & set the choke.
Old 08-06-2004, 07:51 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Yeah I think we've all "heard" about the servo/solonoid that moves the throttle to start a carbed car, but I doubt anybody ever has actually SEEN one of these contraptions. Your best bet if you're really wanting to do it would be to just get something that would add some fuel for you before the motor cranks. I guess you'd still have to worry about the choke not working... Personally, I don't want anything tugging on my throttle except for ME. The thought of having an electrial part with partial control over my throttle doesn't sit well... (and let me pre-empt statments about cruise control-a system proven over the last 20 years).
I think its probably more trouble than its worth.
K
Old 08-06-2004, 02:24 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
If it's like my caprice you'll also need something that can pump your gas pedal for you 3-4 times before it starts cranking over.
Old 08-06-2004, 02:31 PM
Siggy_Freud's Avatar
Too much hassle on carb vehicles. I suppose you could use it once the car is already heated up and hasn't been sitting for a long period but that about it.
Bringing history and technology together.
Old 08-06-2004, 03:17 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've put remote start on all of my vehicles here in Alaska, and they're great. I use AstroStarts, top of the line and work very well.
On my carburated '86 Chevy truck I installed a Design Tech with their carb kit (part #20036) and it started every time, always on the first try at -20 degrees.
Some people think remote starters are exotic, but in cold country you'll find more cars with them than without, carburated included.
Here's their site, read the FAQ area for more information:
http://www.designtech-intl.com/
Larry
Old 01-24-2005, 08:30 PM
El Chingon's Avatar
Anyone have any success adding it on to an existing alarm?
I have a Clifford Matrix 3.5 with the remote start already built into it.
The car is a 1968 carb'd Lincoln Continental. I can get it to crank via the alarm, but it won't sense that the car is running to stop shutting it off and trying to start it again. Any tips or advice other than it is too much work appreciated.
Old 01-24-2005, 09:10 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Is the tach wire connected to the coil? If so, it is probably in the programing of the unit, normally a set of dip switches. In mine (Astroflex) the first four switches determine the level of programming and the next five set the options. You may have to program the RPM limit and or number of cylinders. Most also have an auto-learn setting where you set the switches appropriately, start the car with a key and a series of blinks on the unit tells when RPM's have been learned. You then set the switches back to neutral, tap the brake and it's done. Clifford may be a little different but I would think it would be fairly typical.
You may also have a conflict where the alarm and start disabling feature (if you have that) are fighting one another. The car starts momentarily and the intrusion system senses no key and shuts it down. Any ignition disable feature should be neutralized or bypassed for the start, for normally 2 to 4 seconds, until it's up and running. That may be programmable or require a bypass module. Since the entire system is Clifford I would assume it's built in.
I've had several Clifford remote starters and never had a problem, they're a nice unit.
Larry
