Thanks for your reply hiimed.----Great site--www.mad---Will keep in my favorate places.------------------------------------------------------------Thanks dollybud for your reply.----Check page 8 out and found some great info.---Which one of the solution did you use to correct your starter problems?----Thanks again
Question?---My starter solenoid is malfunctioning -----The starter solenoid is by-passing the high resistence wire between the ignition switch and the positive (+) side of the coil.----Now by adding a remote starter solenoid-- will this fix the problem or must i replace the exsiting solenoid and starter motor before i add the remote starter.----Thanks Guys
