Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - remote starter switch
Old 10-16-2012, 11:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by moish View Post
The assembled remote starter switch I made is comprised of an ignition start switch, 2- 12ga. wires each with an alligator clip attached. I want to engage the starter w/o turning the engine over. I do not know what 2 terminals to place the clips so that when I "hit" the button, the starter engages but the engine doesn't. Again this is for a 2002 Toyota Tacoma.
Thank you,
Moish
It sounds like you're still asking. Did you see: remote starter switch?
I believe (if you have a manual trans?) you might be able to use the relay terminal but that will not work w/alligator clips w/o making jumpers for the female terminals to connect to the remote switch.
